[QGIS-trac] Re: [Quantum GIS] #3030: Query Builder in Properties produces "Query Failed"
Quantum GIS qgis at qgis.org
Wed Sep 22 04:32:16 EDT 2010
        Reporter:  alobo                             |         Owner:  jef
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.6.0
       Component:  Vectors                           |       Version:  Trunk
      Resolution:  upstream                          |      Keywords:
Platform_version:  ubuntu 9.10                       |      Platform:  All
        Must_fix:  Yes                               |   Status_info:  0
Changes (by jef):
  * status:  reopened => closed
  * resolution:  => upstream
Comment:
 Seems to be an OGR (vector part of GDAL) problem:
 ogrinfo -sql "SELECT * FROM polsfl1_1000 WHERE ID=12" polsfl1_1000.shp
 INFO: Open of `polsfl1_1000.shp'
       using driver `ESRI Shapefile' successful.
 ERROR 1: SQL: Unrecognised field name coords.x1.
 Looks like the attributes with dots in the name are the actual problem for
 OGR (the query is the same as the one the OGR provider uses.
 I see the same on Windows, so I suppose Gerhard didn't use that shape,
 when testing on Windows.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3030#comment:9>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
