[QGIS-trac] Re: [Quantum GIS] #3024: (OsX Leopard) "Calendar" and "File name" edit widgets are not working
Quantum GIS qgis at qgis.org
Wed Sep 22 11:03:19 EDT 2010
   Reporter:  lutra                             |              Owner:  kyngchaos
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.6.0
  Component:  GUI                               |            Version:  1.5.0
   Keywords:                                    |   Platform_version:
   Platform:  OS X                              |           Must_fix:  Yes
Status_info:  0                                 |
Comment(by zealmeida):
 I’m the colleague mentioned above and I’m new to GIS applications, so I
 apologize in advance for any imprecision in my writing (as in my english…)
 It seems to be a problem with the row height. When opening the Attribute
 table window, if some column as a widget like ‘calendar’,  size when I
 double clic in toggle editing mode to edit,   with the standard cell size
 I can only see a non editable small blank line. If I extend the row height
 (extending the column width makes no difference) then the ‘…’ button is
 visible and I can access the calendar window to choose a date as field
 contents. It happens the same with the ‘file name’ widget.
 Some screenshots in the attachment (hopefully) will illustrate this.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3024#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
