[QGIS-trac] Re: [Quantum GIS] #192: Map composer needs a north arrow
Quantum GIS qgis at qgis.org
Fri Sep 24 11:48:08 EDT 2010
        Reporter:  g_j_m             |         Owner:  mhugent
            Type:  enhancement       |        Status:  reopened
        Priority:  minor: annoyance  |     Milestone:  Version 1.6.0
       Component:  Printing          |       Version:  Trunk
      Resolution:                    |      Keywords:
Platform_version:                    |      Platform:  All
        Must_fix:  No                |   Status_info:  0
Comment(by marisn):
 Replying to [comment:17 pcav]:
 > I miss the point here: we do have north arrows, and they can be synced
 to map content. I suggest closing this ticket.
 No. They can't be synced from map. (Tested r14195) Only rotated symbol is
 provided by "North arrow" plugin, map composer has NONE. Adjusting symbol
 rotation by hand doesn't count.
 pcav, if You have problem with understanding this issue, do following:
  * Open Your Countires or whole Europe vector map;
  * Set SRS to Projected -> Steregraphic -> Sea Ice Stereographic North;
  * Enable OTFR;
  * Open "Map composer" and add map view;
  * Place north arrow without manually adjusting it's rotation.
 or simply open example attached to this ticket.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/192#comment:18>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
