[QGIS-trac] [Quantum GIS] #3058: print composer: exporting to PDF does not resize correctly vectors if symbology is in mm. Works fine if units are map units.
Quantum GIS qgis at qgis.org
Tue Sep 28 06:34:54 EDT 2010
   Reporter:  lutra                             |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.6.0
  Component:  Printing                          |            Version:  Trunk
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  Yes
Status_info:  0                                 |
 Add a point vector layer and in ita symbology assign to it a pretty large
 size in millimeters.
 Open the print composer and export to PDF: the size of points does not
 scale as in the composer/canvas.
 Same process, but now define the size in map units instead of mm:
 exporting to PDF produce a correct result.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3058>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
