[QGIS-trac] Re: [Quantum GIS] #3704: Shapefile: please improve column management
Quantum GIS qgis at qgis.org
Tue Apr 5 14:36:25 EDT 2011
        Reporter:  Stemby                            |         Owner:  nobody
            Type:  enhancement                       |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.7.0
       Component:  Data Provider                     |       Version:  1.6.0
      Resolution:  invalid                           |      Keywords:  shapefile column
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Changes (by lutra):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Shapefiles columns can be added without any obstacle in many ways: trough
 the attributes table itself, trough the vector properties, trough the
 field calculator, etc.
 Columns cannot be removed but this IS a OGR limitation: in the gdal/ogr
 trac you'll find a ticket and a patch that awaits to be committed. Until
 then QGIS (and any other software that uses gdal/ogr) can only use a
 workaround to delete shapefile columns. In QGIS this "workaround" is a
 plugin called TABLE MANAGER.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3704#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
