[QGIS-trac] [Quantum GIS] #3724: Direct the user to the format-specific documentation for "Creation Options"
Quantum GIS qgis at qgis.org
Wed Apr 13 03:18:59 EDT 2011
   Reporter:  Alister           |              Owner:  brushtyler
       Type:  enhancement       |             Status:  new
   Priority:  minor: annoyance  |          Milestone:  Version 1.7.0
  Component:  GDALTools         |            Version:  Trunk
   Keywords:                    |   Platform_version:
   Platform:  All               |           Must_fix:  No
Status_info:  0                 |
 Some of the raster tools, such as translate, provide a "Creation Options"
 section (see the attached screenshot).  It is very difficult for users to
 locate the documentation to find out what options are available.  I
 suggest adding a help button to the creation options section, which would
 be something like this:
 '''Raster translate - creation options'''
 Use the add button to add format specific creation options for the output
 file.
 To see what options are available for your selected output file format,
 visit http://gdal.org/formats_list.html, click on the format, and scroll
 down until you find the list of creation options.
 e.g. to create accompanying world files with output tiff images, use the
 TFW=YES option, by entering "tfw" for the option name and "yes" for the
 value.
 There might be a better way to provide this information; perhaps via a
 tooltip (does QT support clickable URLs in a tooltip?).  Or maybe it
 should just be added to the manual.
 If there are any options that are likely to be very popular, it might be
 worth adding startup tips for them.  Maybe the TFW option is an example:
 Tip: Some other software requires world files to display geotiffs in the
 correct location.
 When creating geotiffs using features such as Raster Translate, you can
 create accompanying world files by using the TFW=YES option.
 Simply check the box to enable Creation Options, click Add, and enter
 "tfw" for the option name and "yes" for the value.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3724>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
