[QGIS-trac] [Quantum GIS] #3735: GDAL stats not used
Quantum GIS qgis at qgis.org
Thu Apr 14 07:24:30 EDT 2011
   Reporter:  rblazek           |              Owner:  rblazek
       Type:  bug               |             Status:  new
   Priority:  minor: annoyance  |          Milestone:  Version 1.7.0
  Component:  Rasters           |            Version:  Trunk
   Keywords:                    |   Platform_version:
   Platform:  All               |           Must_fix:  No
Status_info:  0                 |
 I'm not sure if this behavior is expected or I am missing something.
 I have a 1 band raster dataset (an elevation DEM) in TIF format.  It has
 statistics computed from "gdalinfo -stats mydata.tif"   However, when I
 open
 it in QGIS (both 1.6 and 1.7 trunk), and look at the Metadata tab in Layer
 properties, there are two sections that contain band stats information.
 The
 first section is labeled "Band 1" and lists the same stats as found using
 gdalinfo.  The second section is labeled "Band" and says "No stats
 collected
 yet" for band 1.  QGIS has to create the stats when I apply a color map or
 stretch.  For large rasters, this takes a while, and must be done each
 time
 it's used in QGIS.
 Has anyone experienced this behavior?  Is this expected?  Is there a way
 to
 let gdal compute all the stats that QGIS needs?  Thanks.
 reported: http://lists.osgeo.org/pipermail/qgis-
 user/2011-March/011550.html
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3735>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
