[QGIS-trac] [Quantum GIS] #3742: Save extent after reprojection
Quantum GIS qgis at qgis.org
Fri Apr 15 09:35:55 EDT 2011
   Reporter:  gislab                            |              Owner:  nobody
       Type:  enhancement                       |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Projection Support                |            Version:
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
 Right now if you load a layer and change the project's projection to
 something else the layer dissapears as the view extent stays the same
 after reprojection.
 It would be more user friendly if extent of the current view would also
 get reprojected and there will be zoomed to after reprojection is
 finished.
 This way the user will not "loose" a layer.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3742>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
