[QGIS-trac] [Quantum GIS] #3743: georeferencer: can't set map coords from map canvas, and other odd behavior
Quantum GIS qgis at qgis.org
Fri Apr 15 09:57:04 EDT 2011
   Reporter:  kyngchaos                         |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Digitising                        |            Version:  Trunk
   Keywords:                                    |   Platform_version:
   Platform:  OS X                              |           Must_fix:  No
Status_info:  0                                 |
 When adding a GCP (Add Point) in the georeferencer window, I can't set the
 map coordinates from the map canvas.  From the Enter Map Coordinates
 dialog, when I click the From Map Canvas button, a duplicate georeferencer
 window pops out of the QGIS application icon in the OSX Dock, then
 minimizes to the Dock, leaving an inactive copy of the georeferencer
 window.  This copy stays on top of (covering) the now-active QGIS map
 window - I can't resize the window, it doesn't respond to mouse clicks
 except to move the window, but I can't move the window offscreen because
 it snaps back so it's completely within the screen.
 Even in what I can see of the QGIS map window, if I click anywhere, at
 least the duplicate window goes away and the minimized window pops back,
 but no GCP is added, and I can't try to add any more.  Also, in the map
 canvas window, if I pan and zoom around, there is no tool to switch back
 to to set the GCP map point.  The only way to get exit all this is to
 bring the minimized back and close it, cancelling the georeferencer
 operation.
 OSX 10.6.7, Qt 4.7.2
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3743>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
