[QGIS-trac] [Quantum GIS] #3744: Different behavior for mapcanvas and layout with scale dependent rendering
Quantum GIS qgis at qgis.org
Fri Apr 15 10:26:53 EDT 2011
   Reporter:  gislab            |              Owner:  nobody
       Type:  bug               |             Status:  new
   Priority:  minor: annoyance  |          Milestone:  Version 1.7.0
  Component:  Build/Install     |            Version:
   Keywords:                    |   Platform_version:
   Platform:  Windows           |           Must_fix:  No
Status_info:  0                 |
 1. Add attached layer
 2. Change projection to EPSG:3395
 3. Set scale dependent rendering to 0-2000000 (2mln)
 4. Enter 2000000 in the scale area, note the layer disappear.
 5. Enter 1999999 in the scale area, note the layer appears again.
 6. Create new print composer and add map from canvas.
 7. Switch to item tab of the composer and enter 2000000 into Map\Scale.
 Note the layer *does not* dissappear.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3744>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
