[QGIS-trac] Re: [Quantum GIS] #3687: Unable to export at dpi > 400
Quantum GIS qgis at qgis.org
Sat Apr 16 19:51:11 EDT 2011
   Reporter:  bderstine                                  |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.7.0
  Component:  Printing                                   |            Version:  Trunk
   Keywords:                                             |   Platform_version:  Windows 7; Kubuntu 10.10 64 bits
   Platform:  All                                        |           Must_fix:  No
Status_info:  1                                          |
Changes (by mayeulk):
  * platform_version:  7 => Windows 7; Kubuntu 10.10 64 bits
  * platform:  Windows => All
Comment:
 I successfully created an A4 600 dpi map (11Mb in png, 3 Mb in vector pdf)
 on Kubuntu 10.10 (64 bits).
 However, I tried an A0 at 600 dpi in png, it failed. First I was asked:
 To create image 28086x19866 requires about 1673 MB of memory. Proceed?
 I clicked yes (my PC has 4GB of RAM). Then there was the message:
 Creation of image with 28086x19866 pixels failed. Export aborted.
 No crash for me however. My test dataset is pure vector: OSM data for
 Milano and surrounding, stored on postgis thanks to  osm2postgresql, using
 rule-based render.
 I was able to export the above in A0 but in vector pdf (20 Mega bytes). If
 you can export in vector pdf, you can convert later on in raster, as a
 workaround (for instance, gimp does this, but command line solutions might
 be less memory hungry).
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3687#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac mailing list
