[QGIS-trac] Re: [Quantum GIS] #2921: Avoid intersection of new polygons.. IS BROKEN
Quantum GIS qgis at qgis.org
Sun Apr 17 05:53:48 EDT 2011
        Reporter:  pinux                             |         Owner:  mhugent
            Type:  bug                               |        Status:  reopened
        Priority:  major: does not work as expected  |     Milestone:  Version 1.7.0
       Component:  Digitising                        |       Version:  Trunk
      Resolution:                                    |      Keywords:  intersection, polygons
Platform_version:                                    |      Platform:  All
        Must_fix:  Yes                               |   Status_info:  0
Comment(by mayeulk):
 I can reproduce the bug on the shapefile I attached with those parameters:
 For the shapefile I attached:
 tolerance: 0.000001 (in map units)
 Mode:to vertex and segment
 It is still unclear to me whether there is originally a hole between A and
 B, or if they are OK and only C is wrong. Is there any reliable way to
 check? Visible inspection is useless even at scale>1:1 and postgis does
 not seem reliable here.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2921#comment:14>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac mailing list
