[QGIS-trac] Re: [Quantum GIS] #2921: Avoid intersection of new polygons.. IS BROKEN
Quantum GIS qgis at qgis.org
Sun Apr 17 06:23:57 EDT 2011
        Reporter:  pinux                             |         Owner:  mhugent
            Type:  bug                               |        Status:  reopened
        Priority:  major: does not work as expected  |     Milestone:  Version 1.7.0
       Component:  Digitising                        |       Version:  Trunk
      Resolution:                                    |      Keywords:  intersection, polygons
Platform_version:                                    |      Platform:  All
        Must_fix:  Yes                               |   Status_info:  0
Comment(by mayeulk):
 Hi Marco,
 I will look at it. In the meantime, I found this:
 same bug with tolerance: 0.0001(in map units)
 same bug with tolerance: 0.1(in map units)
 However, with tolerance: 1 (in map units, Mode:to vertex and segment ),
 then there is snapping during digitization of each point, and with
 snapping I could not reproduce the bug anymore with r15718. (In fact,
 snapping makes the set operation unnecessary and probably the bug cannot
 appear).
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2921#comment:16>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac mailing list
