[QGIS-trac] Re: [Quantum GIS] #3531: Bug: QgisApp instance never delete
Quantum GIS qgis at qgis.org
Sun Apr 17 09:28:08 EDT 2011
   Reporter:  05092009                                |              Owner:  nobody
       Type:  bug                                     |             Status:  new
   Priority:  major: does not work as expected        |          Milestone:  Version 1.7.0
  Component:  GUI                                     |            Version:  Trunk
   Keywords:  QgissApp, big memory leak, serious bug  |   Platform_version:
   Platform:  All                                     |           Must_fix:  Yes
Status_info:  0                                       |
Comment(by 05092009):
 Just set a breakpoint in QgisApp's destructor, and close application.
 Debugger won't go there.
 Try to have a look on the code. QgisApp, as you know, is a singleton. It's
 instance is created in funcion main (main.cpp), but instance should be
 deleted in a straightforward way, by calling delete. Instead of these, no
 delete called and main just returns QApplication's exec.
 That causes all the data, associated with QgisApp to stay in memory 4ever.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3531#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac mailing list
