[QGIS-trac] Re: [Quantum GIS] #3190: SVG markers with centered labels issue
Quantum GIS qgis at qgis.org
Sun Apr 17 17:01:13 EDT 2011
        Reporter:  dr                                |         Owner:  wonder
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.7.0
       Component:  Symbology                         |       Version:  Trunk
      Resolution:  upstream                          |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Changes (by wonder):
  * status:  new => closed
  * resolution:  => upstream
Comment:
 Unfortunately this is how Qt loads that SVG, so it's not actually QGIS
 problem - if you open SVG Viewer example from "qtdemo" application, it
 will display the SVG in the same way as QGIS does. Please file a bug in Qt
 for this issue.
 As a workaround consider transforming that text to a path in a vector
 editor...
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3190#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac mailing list
