[QGIS-trac] [Quantum GIS] #3757: "use project crs" does not work correctly
Quantum GIS qgis at qgis.org
Mon Apr 18 02:56:59 EDT 2011
   Reporter:  Alister                           |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Projection Support                |            Version:  Trunk
   Keywords:                                    |   Platform_version:  XP
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
 "Options>CRS>Coordinate Reference System for new layers>Use project CRS"
 does not work correctly:
 When loading a layer which does not have a CRS, it is set to the
 ''original'' project CRS, not the current project CRS.  So if I click
 "File-New Project", then add a layer which does not have a CRS, then
 change the project CRS, then add another layer, the second layer will be
 assigned the same CRS as the first layer.
 I am using r15740.  The behaviour is the same for both raster and vector
 layers.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3757>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac mailing list
