[QGIS-trac] Re: [Quantum GIS] #3755: gdalwarp error# 126: cannot find gdal_ECW_JP2ECW.dll
Quantum GIS qgis at qgis.org
Mon Apr 18 03:55:24 EDT 2011
        Reporter:  howslo                            |         Owner:  nobody
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.7.0
       Component:  Build/Install                     |       Version:  Trunk
      Resolution:  invalid                           |      Keywords:
Platform_version:  Win 7 64x                         |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Changes (by lutra):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 The error will go away if you remove the gdal-ecw package.
 It does not make sense to install it if you then do not copy the dlls from
 the ERDAS ECW/JP2 SDK in your system.
 The "Failed to allocate 375378345 byte source buffer" message can be
 something else, but I suggest to open another ticket.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3755#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac mailing list
