[QGIS-trac] Re: [Quantum GIS] #2227: GPS Tools: "Import other file" doesn't work
Quantum GIS qgis at qgis.org
Thu Apr 21 03:47:24 EDT 2011
        Reporter:  dr                                |         Owner:  gjm
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.7.0
       Component:  C++ Plugins                       |       Version:  Trunk
      Resolution:  fixed                             |      Keywords:  GPS, GPX
Platform_version:                                    |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Changes (by jef):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:12 alexbruy]:
 > Just tried to import shapefile with GPS Tools. Other files tab, select
 point shapefile and Shapefile (*.*) from file type combo. After clicking
 Ok button I get error message
 > Could not import data from F:/samples/shape/poi-osm.shp!
 > Input type 'shape' not recognized
 > Windows XP, r15786. In Linux with same revision and same test data all
 works fine
 your gpsbabel probably doesn't support shape.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2227#comment:14>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac mailing list
