[QGIS-trac] Re: [Quantum GIS] #3769: PostGIS connections: take them from PgAdmin3?
Quantum GIS qgis at qgis.org
Sat Apr 23 08:52:47 EDT 2011
   Reporter:  pcav              |              Owner:  nobody
       Type:  enhancement       |             Status:  new
   Priority:  minor: annoyance  |          Milestone:  Version 1.7.0
  Component:  Data Provider     |            Version:
   Keywords:                    |   Platform_version:
   Platform:  All               |           Must_fix:  No
Status_info:  0                 |
Comment(by mayeulk):
 A few notes on this interesting idea:
 - If you have 30 databases on 3 local servers (e.g. dev, testing, prod)
 and only one of those databases has tables with spatial objects, you do
 not want to list them all in qgis. So you should be given the choice.
 - In any case this should be optional (you should be able to configure
 it manually, and you still need to give a password if you are not using
 a socket or another method of authentification).
 - This relies on knowing where this pgadmin config file is. I guess it
 is in ~/pgadmin3 in most GNU/Linux box.
 In qgis developer mailing list, Alessandro F. said:
 "WinOz doesn't uses any file to store permanent
 settings: it uses the System Registry instead.
 so pgadmin connections are stored under the
 following registry key:
 HKEY_CURRENT_USER/Software/pgAdmin III/Servers
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3769#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac mailing list
