[QGIS-trac] [Quantum GIS] #3770: Cannot add parts to multipoint or multilinestring feature
Quantum GIS qgis at qgis.org
Sat Apr 23 09:10:11 EDT 2011
   Reporter:  mayeulk           |              Owner:
       Type:  bug               |             Status:  new
   Priority:  minor: annoyance  |          Milestone:  Version 1.7.0
  Component:  Vectors           |            Version:
   Keywords:                    |   Platform_version:
   Platform:  All               |           Must_fix:  No
Status_info:  0                 |
 Not all buttons in the advance editing toolbar are available for
 all geometry types: you cannot add parts to multipoint or multilinestring
 feature, but can with multipolygons.
 Tested with r 15754 and postgis as a backend:
 * You cannot add a point to a multipoint feature (you can only add a new
 feature). You can move or delete one of its parts . You can copy a
 multipoint feature and paste it as a new multipoint feature.
 * You cannot add a part to a multiline string (you can only add a new
 feature). You can move or delete one of its parts. You can copy a
 multiline feature and paste it as a new multiline feature.
 * You can add and delete parts to multipolygon. (As a minor note, to
 delete a part of a multipolygon. you have to click on one of its
 vertice, which *might* be a problem if you have a set of contiguous
 (parts of) polygons).
 As a side point, note that it is the responsibility of the backend to
 generate new id's when copy/pasting to avoid duplicates, e.g. with:
 ALTER TABLE test_multipoints
   ADD CONSTRAINT test_multipoints_pkey PRIMARY KEY(id);
 otherwise duplicated id's are created (which does not prevent most
 functions to work apparently).
 I consider this as an annoyance more than a major bug because you can
 always create more features and duplicate the attributes, potentially with
 a field like relation_id (the OSM way from a conceptual point of view). If
 two points belong to the same relation (should be a multipoint), then they
 have the same relation_id. Still, if you already have a database with
 multi* geometries and *must* keep this structure, fixing this bug will
 help.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3770>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac mailing list
