[QGIS-trac] Re: [Quantum GIS] #3772: qgis 1.6 crash if want save project
Quantum GIS qgis at qgis.org
Mon Apr 25 12:18:19 EDT 2011
   Reporter:  bo27up                                     |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:
  Component:  Project Loading / Saving                   |            Version:  1.6.0
   Keywords:  project file                               |   Platform_version:
   Platform:  Debian                                     |           Must_fix:  Yes
Status_info:  1                                          |
Comment(by bo27up):
 Replying to [comment:1 lutra]:
 > please attach/link a sample of data (project+data) to try replicate
 locally.
 Thank you for fast reply!
 I'm working with Grass Plugin on QGIS. Here are the steps which leads to a
 crash.
 1. Load a Polygon (Grass-)Data
 2. Load Raster (Grass-)Data
 3. Try to save Project => Crash, Project Data is damaged
 4. Open Project again (project data was saved on another place before)
 5. Close Raster Data, then try to save => it works!
 6. Close Project and restart Project (only Polygon Data is loaded as saved
 before)
 7. Try to save => it works!
 8. Then open Raster Data again and try to save (Polygon and Raster) => it
 works!
 9. Close Project and restart Project again
 10. Try to save => Crash, Project Data is damaged.
 11. If I repeat step 4. until 10. I get the same behavior as decribes.
 So QGIS crashes if Polygon and Raster Data is loaded, but only after
 second save-process. In the first time when its loaded (Polygon and
 Raster), its no problem with saving. After restart the Project the save-
 process crashes every time. If there is only Polygon Data loaded, there is
 no problem.
 It's not possible for me to attach Data because there is a limit of 256kb.
 I will try to generate smaller sample data.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3772#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac mailing list
