[QGIS-trac] Re: [Quantum GIS] #3725: Offline Editing plugin issues on both Linux and Windows using trunk (was: Offline Editing plugin)
Quantum GIS qgis at qgis.org
Wed Apr 27 06:32:16 EDT 2011
   Reporter:  elcuco                                     |              Owner:  mwalker
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.7.0
  Component:  C++ Plugins                                |            Version:  Trunk
   Keywords:                                             |   Platform_version:
   Platform:  All                                        |           Must_fix:  Yes
Status_info:  0                                          |
Changes (by lutra):
 * cc: jef (added)
  * priority:  major: does not work as expected => critical: causes crash
               or data corruption
  * version:  => Trunk
  * must_fix:  No => Yes
Comment:
 I finally found the time to do a little testing myself.
 Before starting just one note:
 to import the table dump attached to this ticket I had to do it using psql
 because for some reason both pgadmin3 and postgis manager failed to run
 the query.
 I also had to run
 SELECT Populate_Geometry_Columns();
 Results:
 I tested the attached table/data on both linux (Ubuntu 10.04 32bit) and
 Windows Seven using QGIS trunk. For the sake of the test I disabled any
 3rd party plugin, as we know sometimes can interfere with core QGIS tools.
 *) Windows: the spatialite DB is created correctly and populated with the
 data. It is possible to edit the SL layer(s) but then no synchronization
 whatsoever is done when clicking the "synchronize" button.
 *) Linux: in the best case the SL database is created but with no data in
 it. Usually QGIS crashes (seg fault) during the SL database creation. This
 seems to happen at the end of the process because the SL file is outputted
 (always empty).
 Here is the empty SL database created under Linux:
 http://ubuntuone.com/p/ovi/
 Jurgen, I change back the "must_fix" tag to "yes" as this seems to me a
 show stopper as it is a core tool. Just my opinion, so feel free to switch
 back again to "no".
 PS
 One of the crashes gave me more (than seg faukt) in the console
 *** glibc detected *** /usr/bin/qgis.bin: corrupted double-linked list:
 0x0bb02110 ***
 ======= Backtrace: =========
 /lib/tls/i686/cmov/libc.so.6(+0x6b591)[0xb54ba591]
 /lib/tls/i686/cmov/libc.so.6(+0x6ce41)[0xb54bbe41]
 /lib/tls/i686/cmov/libc.so.6(cfree+0x6d)[0xb54beecd]
 /usr/lib/libqgis_core.so.1.7.0(+0x28ce4d)[0xb7261e4d]
 /usr/lib/libqgis_core.so.1.7.0(+0x28ceae)[0xb7261eae]
 /usr/lib/libqgis_core.so.1.7.0(SPLite3_clear_bindings+0x4d)[0xb7265b0d]
 /usr/lib/qgis/plugins/libspatialiteprovider.so(_ZN21QgsSpatiaLiteProvider11addFeaturesER5QListI10QgsFeatureE+0xcc5)[0xb0f02755]
 /usr/lib/libqgis_core.so.1.7.0(_ZN14QgsVectorLayer13commitChangesEv+0x2db5)[0xb7186b75]
 /usr/lib/qgis/plugins/libofflineeditingplugin.so(_ZN17QgsOfflineEditing15copyVectorLayerEP14QgsVectorLayerP7sqlite3RK7QString+0x1791)[0xb102b811]
 /usr/lib/qgis/plugins/libofflineeditingplugin.so(_ZN17QgsOfflineEditing23convertToOfflineProjectERK7QStringS2_RK11QStringList+0x1bd)[0xb102c4cd]
 /usr/lib/qgis/plugins/libofflineeditingplugin.so(_ZN23QgsOfflineEditingPlugin14convertProjectEv+0x10c)[0xb101e1cc]
 /usr/lib/qgis/plugins/libofflineeditingplugin.so(_ZN23QgsOfflineEditingPlugin11qt_metacallEN11QMetaObject4CallEiPPv+0xb3)[0xb102ec83]
 /usr/lib/libQtCore.so.4(_ZN11QMetaObject8metacallEP7QObjectNS_4CallEiPPv+0x3a)[0xb6c32c9a]
 /usr/lib/libQtCore.so.4(_ZN11QMetaObject8activateEP7QObjectPKS_iPPv+0x2d5)[0xb6c413d5]
 /usr/lib/libQtGui.so.4(_ZN7QAction9triggeredEb+0x49)[0xb6177bd9]
 /usr/lib/libQtGui.so.4(_ZN7QAction8activateENS_11ActionEventE+0x7c)[0xb6179dcc]
 /usr/lib/libQtGui.so.4(_ZN11QToolButton14nextCheckStateEv+0x32)[0xb666cbd2]
 /usr/lib/libQtGui.so.4(+0x540cb3)[0xb6589cb3]
 /usr/lib/libQtGui.so.4(_ZN15QAbstractButton17mouseReleaseEventEP11QMouseEvent+0x9e)[0xb6589fae]
 /usr/lib/libQtGui.so.4(_ZN11QToolButton17mouseReleaseEventEP11QMouseEvent+0x2c)[0xb666d09c]
 /usr/lib/libQtGui.so.4(_ZN7QWidget5eventEP6QEvent+0x528)[0xb61dc7f8]
 /usr/lib/libQtGui.so.4(_ZN15QAbstractButton5eventEP6QEvent+0x3e)[0xb6588d4e]
 /usr/lib/libQtGui.so.4(_ZN11QToolButton5eventEP6QEvent+0x4a)[0xb666fbca]
 /usr/lib/libQtGui.so.4(_ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent+0xac)[0xb617e4dc]
 /usr/lib/libQtGui.so.4(_ZN12QApplication6notifyEP7QObjectP6QEvent+0xb17)[0xb61859f7]
 /usr/lib/libqgis_core.so.1.7.0(_ZN14QgsApplication6notifyEP7QObjectP6QEvent+0x33)[0xb70bea13]
 /usr/lib/libQtCore.so.4(_ZN16QCoreApplication14notifyInternalEP7QObjectP6QEvent+0x7b)[0xb6c2da3b]
 /usr/lib/libQtGui.so.4(_ZN19QApplicationPrivate14sendMouseEventEP7QWidgetP11QMouseEventS1_S1_PS1_R8QPointerIS0_Eb+0xf2)[0xb6184952]
 /usr/lib/libQtGui.so.4(+0x1c7088)[0xb6210088]
 /usr/lib/libQtGui.so.4(_ZN12QApplication15x11ProcessEventEP7_XEvent+0x1771)[0xb620f511]
 /usr/lib/libQtGui.so.4(+0x1f560a)[0xb623e60a]
 /lib/libglib-2.0.so.0(g_main_context_dispatch+0x1d5)[0xb50a35e5]
 /lib/libglib-2.0.so.0(+0x3f2d8)[0xb50a72d8]
 /lib/libglib-2.0.so.0(g_main_context_iteration+0x68)[0xb50a74b8]
 /usr/lib/libQtCore.so.4(_ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE+0x65)[0xb6c595d5]
 /usr/lib/libQtGui.so.4(+0x1f5135)[0xb623e135]
 /usr/lib/libQtCore.so.4(_ZN10QEventLoop13processEventsE6QFlagsINS_17ProcessEventsFlagEE+0x49)[0xb6c2c059]
 /usr/lib/libQtCore.so.4(_ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE+0xfa)[0xb6c2c4aa]
 /usr/lib/libQtCore.so.4(_ZN16QCoreApplication4execEv+0xaf)[0xb6c3069f]
 /usr/lib/libQtGui.so.4(_ZN12QApplication4execEv+0x27)[0xb617e577]
 /usr/bin/qgis.bin(main+0x223c)[0x8105c1c]
 /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe6)[0xb5465bd6]
 /usr/bin/qgis.bin[0x8103201]
 ======= Memory map: ========
 08048000-085ad000 r-xp 00000000 08:01 3671850    /usr/bin/qgis.bin
 085ad000-085ae000 r--p 00564000 08:01 3671850    /usr/bin/qgis.bin
 085ae000-085b2000 rw-p 00565000 08:01 3671850    /usr/bin/qgis.bin
 085b2000-085b4000 rw-p 00000000 00:00 0
 09129000-0c3f4000 rw-p 00000000 00:00 0          [heap]
 a8605000-a8a13000 rw-p 00000000 00:00 0
 a8e1a000-a8e7a000 rw-s 00000000 00:04 1966117    /SYSV00000000 (deleted)
 a8e7a000-a8e7e000 r-xp 00000000 08:01 3672096
 /usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
 a8e7e000-a8e7f000 r--p 00003000 08:01 3672096
 a8e7f000-a8e80000 rw-p 00004000 08:01 3672096
 a8e81000-a8ee1000 rw-s 00000000 00:04 1933348    /SYSV00000000 (deleted)
 a9259000-a92d9000 r--p 00000000 08:01 3803354    /usr/share/fonts/truetype
 /ttf-dejavu/DejaVuSans-BoldOblique.ttf
 a92d9000-a92e9000 r-xp 00000000 08:01 1704432    /lib/libresolv-2.11.1.so
 a92e9000-a92ea000 r--p 00010000 08:01 1704432    /lib/libresolv-2.11.1.so
 a92ea000-a92eb000 rw-p 00011000 08:01 1704432    /lib/libresolv-2.11.1.so
 a92eb000-a92ed000 rw-p 00000000 00:00 0
 a92ed000-a92ee000 ---p 00000000 00:00 0
 a92ee000-a9aee000 rw-p 00000000 00:00 0
 a9af3000-a9b07000 r--p 00000000 08:01 3831160
 /usr/share/fonts/type1/gsfonts/n019003l.pfb
 a9b07000-a9b08000 ---p 00000000 00:00 0
 a9b08000-aa308000 rw-p 00000000 00:00 0
 aa308000-aa309000 ---p 00000000 00:00 0
 aa309000-aab09000 rw-p 00000000 00:00 0
 aab09000-aab0a000 ---p 00000000 00:00 0
 aab0a000-ab30a000 rw-p 00000000 00:00 0
 ab30a000-ab326000 r-xp 00000000 08:01 4461097
 /usr/lib/R/library/grid/libs/grid.so
 ab326000-ab327000 r--p 0001b000 08:01 4461097
 ab327000-ab328000 rw-p 0001c000 08:01 4461097
 ab328000-ab389000 r-xp 00000000 08:01 4460646
 /usr/lib/R/library/stats/libs/stats.so
 ab389000-ab38a000 r--p 00061000 08:01 4460646
 ab38a000-ab38b000 rw-p 00062000 08:01 4460646
 ab38b000-ab38c000 rw-p 00000000 00:00 0
 ab38c000-ab3ae000 r-xp 00000000 08:01 4460485
 /usr/lib/R/library/grDevices/libs/grDevices.so
 ab3ae000-ab3af000 r--p 00021000 08:01 4460485
 ab3af000-ab3b0000 rw-p 00022000 08:01 4460485
 ab3b0000-ab3e4000 r-xp 00000000 08:01 1704038    /lib/libncurses.so.5.7
 ab3e4000-ab3e5000 ---p 00034000 08:01 1704038    /lib/libncurses.so.5.7
 ab3e5000-ab3e7000 r--p 00034000 08:01 1704038    /lib/libncurses.so.5.7
 ab3e7000-ab3e8000 rw-p 00036000 08:01 1704038    /lib/libncurses.so.5.7
 ab3e8000-ab3f8000 r-xp 00000000 08:01 1704275    /lib/libbz2.so.1.0.4
 ab3f8000-ab3f9000 r--p 0000f000 08:01 1704275    /lib/libbz2.so.1.0.4
 ab3f9000-ab3fa000 rw-p 00010000 08:01 1704275    /lib/libbz2.so.1.0.4
 ab3fa000-ab429000 r-xp 00000000 08:01 1704096    /lib/libreadline.so.6.1
 ab429000-ab42a000 r--p 0002e000 08:01 1704096    /lib/libreadline.so.6.1
 ab42a000-ab42d000 rw-p 0002f000 08:01 1704096    /lib/libreadline.so.6.1
 ab42d000-ab42e000 rw-p 00000000 00:00 0
 ab436000-ab444000 r-xp 00000000 08:01 3810393    /usr/lib/python2.6/lib-
 dynload/_sqlite3.so
 ab444000-ab445000 r--p 0000d000 08:01 3810393    /usr/lib/python2.6/lib-
 dynload/_sqlite3.so
 ab445000-ab447000 rw-p 0000e000 08:01 3810393    /usr/lib/python2.6/lib-
 dynload/_sqlite3.so
 ab447000-ab6be000 r-xp 00000000 08:01 4457232    /usr/lib/R/lib/libR.so
 ab6be000-ab6bf000 ---p 00277000 08:01 4457232    /usr/lib/R/lib/libR.so
 ab6bf000-ab6c2000 r--p 00277000 08:01 4457232    /usr/lib/R/lib/libR.so
 ab6c2000-ab6cd000 rw-p 0027a000 08:01 4457232    /usr/lib/R/lib/libR.so
 ab6cd000-ab764000 rw-p 00000000 00:00 0
 ab764000-ab8ba000 r-xp 00000000 08:01 4470510
 /usr/lib/pyshared/python2.6/PyQt4/Qwt5/Qwt.so
 ab8ba000-ab8bd000 r--p 00156000 08:01 4470510
 ab8bd000-ab8ce000 rw-p 00159000 08:01 4470510
 ab8ce000-abfaf000 r-xp 00000000 08:01 3675949
 /usr/lib/libQtDesigner.so.4.6.2
 abfaf000-abfb0000 ---p 006e1000 08:01 3675949
 abfb0000-abfbe000 r--p 006e1000 08:01 3675949
 abfbe000-abfc0000 rw-p 006ef000 08:01 3675949
 abfc0000-abfc1000 rw-p 00000000 00:00 0
 abfc1000-abff8000 r-xp 00000000 08:01 4345402
 /usr/lib/pyshared/python2.6/PyQt4/QtDesigner.so
 abff8000-abffa000 r--p 00037000 08:01 4345402
 abffa000-ac000000 rw-p 00039000 08:01 4345402
 ac000000-ac006000 r-xp 00000000 08:01 3673721
 /usr/lib/libQtAssistantClient.so.4.6.2
 ac006000-ac007000 r--p 00005000 08:01 3673721
 ac007000-ac008000 rw-p 00006000 08:01 3673721
 ac008000-ac025000 r-xp 00000000 08:01 4345403
 /usr/lib/pyshared/python2.6/PyQt4/QtXmlPatterns.so
 ac025000-ac026000 r--p 0001c000 08:01 4345403
 ac026000-ac02a000 rw-p 0001d000 08:01 4345403
 ac02a000-ac0a1000 r-xp 00000000 08:01 3675961
 /usr/lib/libQtDBus.so.4.6.2
 ac0a1000-ac0a2000 r--p 00076000 08:01 3675961
 ac0a2000-ac0a3000 rw-p 00077000 08:01 3675961
 ac0a3000-ac49c000 r-xp 00000000 08:01 3673209
 /usr/lib/libQtXmlPatterns.so.4.6.2
 ac49c000-ac4bc000 r--p 003f8000 08:01 3673209
 ac4bc000-ac4bd000 rw-p 00418000 08:01 3673209
 ac4bd000-ac4be000 rw-p 00000000 00:00 0
 ac4be000-ac510000 r-xp 00000000 08:01 3674406
 /usr/lib/libphonon.so.4.4.0
 ac510000-ac512000 r--p 00051000 08:01 3674406
 ac512000-ac513000 rw-p 00053000 08:01 3674406
 ac513000-ad489000 r-xp 00000000 08:01 3673153
 /usr/lib/libQtWebKit.so.4.6.2
 ad489000-ad51c000 r--p 00f75000 08:01 3673153
 ad51c000-ad522000 rw-p 01008000 08:01 3673153
 ad522000-ad535000 rw-p 00000000 00:00 0
 ad535000-ad57a000 r-xp 00000000 08:01 4345397
 /usr/lib/pyshared/python2.6/PyQt4/QtWebKit.so
 ad57a000-ad57b000 r--p 00045000 08:01 4345397
 ad57b000-ad584000 rw-p 00046000 08:01 4345397
 ad584000-ad5a7000 r-xp 00000000 08:01 3676955
 /usr/lib/libQtTest.so.4.6.2
 ad5a7000-ad5a8000 r--p 00022000 08:01 3676955
 ad5a8000-ad5a9000 rw-p 00023000 08:01 3676955
 ad5af000-ad5b5000 r-xp 00000000 08:01 4460992
 /usr/lib/R/library/methods/libs/methods.so
 ad5b5000-ad5b6000 r--p 00005000 08:01 4460992
 ad5b6000-ad5b7000 rw-p 00006000 08:01 4460992
 ad5b7000-ad5bf000 r-xp 00000000 08:01 4463734    /usr/lib/python2.6/dist-
 packages/rpy2/rinterface/rinterface.so
 ad5bf000-ad5c0000 r--p 00007000 08:01 4463734    /usr/lib/python2.6/dist-
 ad5c0000-ad5c2000 rw-p 00008000 08:01 4463734    /usr/lib/python2.6/dist-
 ad5c2000-ad677000 r-xp 00000000 08:01 3675953
 /usr/lib/libQtScriptTools.so.4.6.2
 ad677000-ad67c000 r--p 000b4000 08:01 3675953
 ad67c000-ad67d000 rw-p 000b9000 08:01 3675953
 ad67d000-ad681000 r-xp 00000000 08:01 1704447
 /lib/tls/i686/cmov/libnss_dns-2.11.1.so
 ad681000-ad682000 r--p 00004000 08:01 1704447
 ad682000-ad683000 rw-p 00005000 08:01 1704447
 ad683000-ad693000 r-xp 00000000 08:01 4345401
 /usr/lib/pyshared/python2.6/PyQt4/QtSvg.so
 ad693000-ad694000 r--p 0000f000 08:01 4345401
 ad694000-ad696000 rw-p 00010000 08:01 4345401
 ad696000-ad8e1000 r-xp 00000000 08:01 3675957
 /usr/lib/libQtScript.so.4.6.2
 ad8e1000-ad8eb000 r--p 0024a000 08:01 3675957
 ad8eb000-ad8ec000 rw-p 00254000 08:01 3675957
 ad8ec000-ad8fc000 rw-p 00000000 00:00 0
 ad8fc000-ad91e000 r-xp 00000000 08:01 4345395
 /usr/lib/pyshared/python2.6/PyQt4/QtScript.so
 ad91e000-ad91f000 r--p 00021000 08:01 4345395
 ad91f000-ad924000 rw-p 00022000 08:01 4345395
 ad924000-ada0d000 r-xp 00000000 08:01 3676965
 /usr/lib/libQtCLucene.so.4.6.2
 ada0d000-ada12000 r--p 000e9000 08:01 3676965
 ada12000-ada13000 rw-p 000ee000 08:01 3676965
 ada13000-ada90000 r-xp 00000000 08:01 3673609
 /usr/lib/libQtHelp.so.4.6.2
 ada90000-ada91000 ---p 0007d000 08:01 3673609
 ada91000-ada93000 r--p 0007d000 08:01 3673609
 ada93000-ada94000 rw-p 0007f000 08:01 3673609
 ada95000-ada97000 r-xp 00000000 08:01 1704057
 /lib/libnss_mdns4_minimal.so.2
 ada97000-ada98000 r--p 00001000 08:01 1704057
 ada98000-ada99000 rw-p 00002000 08:01 1704057
 ada99000-ada9c000 r-xp 00000000 08:01 4345396
 /usr/lib/pyshared/python2.6/PyQt4/QtAssistant.so
 ada9c000-ada9d000 r--p 00002000 08:01 4345396
 ada9d000-ada9e000 rw-p 00003000 08:01 4345396
 ada9e000-adaa5000 r-xp 00000000 08:01 4345406
 /usr/lib/pyshared/python2.6/PyQt4/QtTest.so
 adaa5000-adaa6000 r--p 00006000 08:01 4345406
 adaa6000-adaa7000 rw-p 00007000 08:01 4345406
 adaa7000-adaab000 r-xp 00000000 08:01 4345400
 /usr/lib/pyshared/python2.6/PyQt4/QtScriptTools.so
 adaab000-adaac000 r--p 00003000 08:01 4345400
 adaac000-adaad000 rw-p 00004000 08:01 4345400
 adaad000-adac1000 r-xp 00000000 08:01 4345404
 /usr/lib/pyshared/python2.6/PyQt4/QtHelp.so
 adac1000-adac2000 r--p 00013000 08:01 4345404
 adac2000-adac5000 rw-p 00014000 08:01 4345404
 adac5000-adc46000 rw-p 00000000 00:00 0
 adc46000-adc4a000 r-xp 00000000 08:01 3810380    /usr/lib/python2.6/lib-
 dynload/_csv.so
 adc4a000-adc4b000 r--p 00003000 08:01 3810380    /usr/lib/python2.6/lib-
 dynload/_csv.so
 adc4b000-adc4d000 rw-p 00004000 08:01 3810380    /usr/lib/python2.6/lib-
 dynload/_csv.so
 adc4d000-adc51000 r-xp 00000000 08:01 3803057    /usr/lib/python2.6/dist-
 packages/sgmlop.soAborted
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3725#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS supporting GDAL/OGR, PostGIS, and GRASS formats, and Web Services
More information about the QGIS-trac mailing list
