[QGIS-trac] [Quantum GIS] #3468: Missing layer in project means I can't load project at all
Quantum GIS qgis at qgis.org
Fri Feb 4 23:13:09 EST 2011
   Reporter:  arencambre                        |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Project Loading / Saving          |            Version:  1.6.0
   Keywords:                                    |   Platform_version:  7
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
 I have a project with 5 layers. One is a ShapeFile that I inadvertently
 deleted.
 When the project loads, I get a '''QGIS Project Read Error''' dialog. See
 attached image. If I select '''Cancel''', then the entire project is
 unloaded. If I press '''OK''' but cannot locate the ShapeFile (and I can't
 because, again, I deleted it) and hit '''Cancel''' in the file browsing
 dialog, then the project also unloads.
 If I press '''Cancel''', or if I press '''OK''' but cannot find the
 project, I should at least have the project loaded without the missing
 layer. Right now, my project is completely unusable until I restore the
 ShapeFile.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3468>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
