[QGIS-trac] Re: [Quantum GIS] #3504: Zoom to full or layer extent fails after OTF transformation
Quantum GIS qgis at qgis.org
Sat Feb 19 13:47:09 EST 2011
   Reporter:  gsherman                          |              Owner:  mhugent
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Build/Install                     |            Version:  Trunk
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  Yes
Status_info:  0                                 |
Comment(by gsherman):
 The change in r15131 may not be the root cause. Projection is not getting
 set when loading a layer (e.g. from the alaska sample set). If you load
 the layer, set the projection to Alaska Albers NAD27 then reproject to
 geographic the zoom full works.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3504#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
