[QGIS-trac] [Quantum GIS] #3529: Default CRS does not work as expected
Quantum GIS qgis at qgis.org
Mon Feb 28 04:08:18 EST 2011
   Reporter:  benoitrsa                                  |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.7.0
  Component:  Projection Support                         |            Version:  Trunk
   Keywords:  CRS,Projection,load,default                |   Platform_version:  Win7, XP
   Platform:  Windows                                    |           Must_fix:  Yes
Status_info:  0                                          |
 In the general "Options" dialog box, CRS tab there are three options for
 the default CRS: (1) Prompt for CRS, (2) Project wide default CRS..., (3)
 Global default CRS...
 When loading a layer (either vector or raster) none of those options
 recognise the layer internal CRS, even if that layer CRS is defined and is
 reported as defined by GDAL.
 This means that, when a layer is loaded:
 - With option (1) the CRS dialog box is ALWAYS presented and the default
 choice is most of the time wrong. Is it extremely frustrating to define
 the CRS for 100's of layers being imported, knowing that those layer HAVE
 an internal CRS (them being GeoTIFs of shapefiles).
 - With option (2) the project CRS is given to the loaded layer,
 irrespective of that layer internal CRS. When OTF is on, this has
 disastrous results as you do not expect the CRS of a loaded layer to be
 changed and find your layer wait out of where it should be!
 - With option (3) the global CRS is given to the loaded layer,
 irrespective of that layer internal CRS. When OTF is on, this has the same
 disastrous results as in option (2)!
 Example:
 1 - Open a new QGIS project and set project CRS to WGS84 UTM30N
 (EPGS:32630)
 2 - Create a shapefile in that CRS, draw some points and save it
 3 - Check with GDAL that its projection is indeed WGS84 UTM30N
 4 - Save project as "Project1"
 5 - Create a new QGIS project, set the project default CRS set to Google
 Mercator (EPSG:900913) and enable on-the-fly projection
 6 - Select option (2) in above dialog box
 7 - Import the shapefile created in step 2.
 8 - Load a google satellite image, with the Google plugin, and realise
 that the shapefile is at the wrong location!
 9 - Use GDAL-Wrap (Raster menu) to convert the google image to GeoTIFF
 with an internal CRS of WGS84 UTM30N.
 10 - Check with GDAL that the internal CRS of the GeoTIFF file is
 correctly defined.
 11 - Load Project1
 12 - Select option (1) in the dialog above
 13 - Load the GeoTIFF file created in step 9.
 14 - QGIS asks for its CRS! In that case the default CRS presented by the
 CRS dialog box is correct because both the GeoTIFF and the project have
 the same CRS.
 Repeat steps 5-14, but in step 6, select option (3).
 You will have similarly wrong results.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3529>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
