[QGIS-trac] Re: [Quantum GIS] #2634: Spatial Query Plugin source for evaluation
Quantum GIS qgis at qgis.org
Mon Feb 28 16:54:14 EST 2011
        Reporter:  lmotta            |         Owner:  timlinux
            Type:  patch             |        Status:  reopened
        Priority:  minor: annoyance  |     Milestone:  Version 1.7.0
       Component:  C++ Plugins       |       Version:  Trunk
      Resolution:                    |      Keywords:  Spatial Query
Platform_version:                    |      Platform:  All
        Must_fix:  No                |   Status_info:  0
Comment(by timlinux):
 Hi
 I get a bunch of errors compiling your latest:
 /home/timlinux/dev/cpp/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp:
 In member function ‘void
 QgsSpatialQueryDialog::showResultQuery(QDateTime*, QDateTime*)’:
 /home/timlinux/dev/cpp/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp:216:
 error: ‘class QComboBox’ has no member named ‘currentItem’
 In member function ‘void QgsSpatialQueryDialog::removeLayer(bool,
 QgsVectorLayer*)’:
 /home/timlinux/dev/cpp/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp:476:
 error: ‘class QGroupBox’ has no member named ‘isShown’
 In member function ‘void QgsSpatialQueryDialog::populateCbTargetLayer()’:
 /home/timlinux/dev/cpp/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp:545:
 warning: ‘QString QgsMapLayer::getLayerID() const’ is deprecated (declared
 at
 /home/timlinux/dev/cpp/qgis/src/plugins/spatialquery/../../core/qgsmaplayer.h:79)
 QgsSpatialQueryDialog::zoomFeature(QgsVectorLayer*, int)’:
 /home/timlinux/dev/cpp/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp:686:
 warning: ‘long int QgsCoordinateReferenceSystem::epsg() const’ is
 deprecated (declared at
 /home/timlinux/dev/cpp/qgis/src/plugins/spatialquery/../../core/qgscoordinatereferencesystem.h:268)
 QgsSpatialQueryDialog::on_pbCreateLayerItems_clicked()’:
 /home/timlinux/dev/cpp/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp:785:
 QgsSpatialQueryDialog::on_cbTargetLayer_currentIndexChanged(int)’:
 /home/timlinux/dev/cpp/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp:865:
 QgsSpatialQueryDialog::on_cbReferenceLayer_currentIndexChanged(int)’:
 /home/timlinux/dev/cpp/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp:878:
 QgsSpatialQueryDialog::on_cbResultFor_currentIndexChanged()’:
 /home/timlinux/dev/cpp/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp:940:
 QgsSpatialQueryDialog::on_lwFeatures_currentItemChanged(QListWidgetItem*)’:
 /home/timlinux/dev/cpp/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp:948:
 QgsSpatialQueryDialog::on_ckbZoomItem_clicked(bool)’:
 /home/timlinux/dev/cpp/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp:974:
 QgsSpatialQueryDialog::signal_qgis_layerWasAdded(QgsMapLayer*)’:
 /home/timlinux/dev/cpp/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp:1002:
 at
 QgsSpatialQueryDialog::signal_qgis_layerWillBeRemoved(QString)’:
 /home/timlinux/dev/cpp/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp:1034:
 make[2]: ***
 [src/plugins/spatialquery/CMakeFiles/spatialqueryplugin.dir/qgsspatialquerydialog.cpp.o]
 Error 1
 make[1]: ***
 [src/plugins/spatialquery/CMakeFiles/spatialqueryplugin.dir/all] Error 2
 make[1]: *** Waiting for unfinished jobs....
 [ 61%] Built target offlineeditingplugin
 [ 62%] Built target spitplugin
 [ 62%] Building CXX object src/app/CMakeFiles/qgis.dir/main.cpp.o
 Linking CXX executable qgis
 I'm using Qt 4.6 on ubuntu. By the way it will be easier for me if you
 just supply your updates as a patch, or a zip of the whole plugin dir as I
 test on different computers and the current way of you supplying updates
 means I need to run through each zip file to make sure I didnt leave
 anything out.
 Once the above problem is resolved, I will probably go ahead and commit
 your updates to trunk.
 Thanks for all the great work!
 Regards
 Tim
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2634#comment:37>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
