[QGIS-trac] Re: [Quantum GIS] #3383: Add a SAGA plugin
Quantum GIS qgis at qgis.org
Mon Jan 3 04:20:42 EST 2011
   Reporter:  pcav                              |              Owner:  borysiasty
       Type:  enhancement                       |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Python plugins and bindings       |            Version:
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
Comment(by johanvdw):
 You are confusing saga  (an api for grid computing
 http://saga.cct.lsu.edu/) with saga gis ( http://www.saga-gis.org ).
 But: saga gis also has a python api based on swig.
 Some examples are here:
 http://sourceforge.net/apps/trac/saga-gis/raw-
 attachment/wiki/MiscWikiFiles/saga_2_python.zip
 In case people are interested: I have a script which parses the module
 parameters to create some test scripts which can be useful as a start
 for such a module - I'll check if everything works ok
 with the current version and try to add some documentation on how to
 build the saga python extensions to the wiki and then ping back.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3383#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
