[QGIS-trac] Re: [Quantum GIS] #3058: print composer: exporting to PDF does not resize correctly vectors if symbology is in mm. Works fine if units are map units.
Quantum GIS qgis at qgis.org
Wed Jan 12 08:58:11 EST 2011
   Reporter:  lutra                             |              Owner:  mhugent
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.6.0
  Component:  Printing                          |            Version:  Trunk
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  Yes
Status_info:  0                                 |
Comment(by zanollim):
 I attached two PDF exported with the composer.
 They both represent the same area at the same scale (1:5000) on the same
 page size (A4).
 The only difference is the quality (100dpi and 300dpi)
 As you can see, they are very different, but they should be identical!
 I think that the 300dpi PDF is a bigger image resized to fit the 1:5000
 scale. I think that this is wrong!
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3058#comment:7>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
