[QGIS-trac] Re: [Quantum GIS] #3345: Bug: Spacing is messed up in composer labels
Quantum GIS qgis at qgis.org
Mon Jan 24 01:13:07 EST 2011
   Reporter:  Alister                           |              Owner:  mhugent
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Printing                          |            Version:  Trunk
   Keywords:  Print, Composer labels, font      |   Platform_version:  XP
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
Comment(by Alister):
 > Both produce output as expected.
 Interesting.  Do you actually have the Calibri font installed?
 > The Qt pdf export should give the same results on all platforms. It does
 however rasterize the text (I guess that's why you use a gdi pdf printer
 instead).
 Yes.  There were also a number of bugs with the built-in pdf export, but I
 can't remember if any are still open.
 Note that ''this'' is not a PDF problem - it also occurs when I print to a
 real printer.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3345#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
