[QGIS-trac] [Quantum GIS] #3436: Default settings for image output
Quantum GIS qgis at qgis.org
Mon Jan 24 12:37:14 EST 2011
   Reporter:  jrm               |              Owner:  nobody
       Type:  enhancement       |             Status:  new
   Priority:  minor: annoyance  |          Milestone:  Version 1.7.0
  Component:  Rasters           |            Version:  Trunk
   Keywords:                    |   Platform_version:
   Platform:  All               |           Must_fix:  No
Status_info:  0                 |
 QGIS' main basic image output is using the TIFF format in its lowest form
 which has a negative impact on performance and user experience.
 For example, these gdal options could be used by default as they maximize
 the compatibility with other GIS tools while still using helpful
 functionalities :
 - COMPRESS=PACKBITS
 - TILED=YES
 - TFW=YES
 - BIGTIFF=IF_NEEDED
 Any user-defined options should override these options so this solution
 would be beneficial to the advanced user and the beginner. A similar
 politic could be used for the pyramids.
 See http://www.osgeo.org/pipermail/qgis-developer/2011-January/012416.html
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3436>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
