[QGIS-trac] Re: [Quantum GIS] #3453: Postgis layer load starts out with unnecessarily expensive query
Quantum GIS qgis at qgis.org
Sun Jan 30 12:05:17 EST 2011
   Reporter:  arencambre                        |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Data Provider                     |            Version:  1.6.0
   Keywords:                                    |   Platform_version:  7
   Platform:  Debian                            |           Must_fix:  No
Status_info:  0                                 |
Comment(by jef):
 Isn't that your view?  views usually don't have an entry in
 {{{geometry_columns}}}.  Additionally the query you mention should only
 run, when the geometry type of the layer is not known beforehand (ie.
 {{{GEOMETRY}}} instead of a specific type).  And with large datasets you
 probably want to enable "use estimated data", which should limit the query
 to deduce the geometry type to the first 100 rows.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3453#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
