[QGIS-trac] [Quantum GIS] #3537: CRS info in shapefile .prj is not taken into account by QGIS
Quantum GIS qgis at qgis.org
Wed Mar 2 00:19:12 EST 2011
   Reporter:  benoitrsa                         |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Projection Support                |            Version:  Trunk
   Keywords:  CRS,Shapefile,PRJ,QPJ             |   Platform_version:  Win7, WinXP & Mac OS X
   Platform:  Windows                           |           Must_fix:  Yes
Status_info:  0                                 |
 On loading a shapefile with associated prj file (no qpj file) the CRS in
 the prj file is ignored by QGIS.
 How to reproduce:
 - Unzip attached file (TestCRS.zip) into a folder
 - Open the Google.qgs project (EPSG:900913 - OTF enabled).
 - In Settings/Options->CRS tab select "Prompt for CRS"
 (this option tells QGIS to ask the user to define the CRS of the
 loaded file if, and only if, it is not defined in the file)
 - Load the Town shapefile (note that there is a prj file defining the CRS
 - EPGS:32630)
 - QGIS asks you to define its CRS. This is wrong.
 - Remove the Town shapefile from the project
 - Rename the prj file to qpj
 - Load the Town shapefile again. You are not asked to define its CRS.
 Expected behaviour.
 The same problem exists with the other two options "Project wide default
 CRS will be used" and "Global default CRS displayed below will be used".
 If there is only a prj file (no qpj file) then QGIS silently changes the
 CRS of the Town shapefile to the CRS of the project or the Global default
 respectively. When OTF is on and the loaded shapefile is not in the same
 CRS as the project/default, it is located at the wrong place.
 I have this problem when I want to import a shapefile (in a projected CRS)
 into a project having a Google Mercator CRS and OTF enabled.
 This bug could be related to bug #3529.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3537>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
