[QGIS-trac] Re: [Quantum GIS] #3437: Add natgrid to IGNF's RGF93 projections
Quantum GIS qgis at qgis.org
Thu Mar 3 11:07:03 EST 2011
        Reporter:  jrm                               |         Owner:  jef
            Type:  patch                             |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.7.0
       Component:  Projection Support                |       Version:  Trunk
      Resolution:  invalid                           |      Keywords:  IGNF
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Comment(by jc):
 To "call the use of the grid" or to "have good results" ?
 If +wktext is enough on your tests, why add here +nadgrids ? Have you got
 tests with the addition you propose here or only with the +wktext clause
 addition alone ?
 I just wonder why you test a patch and propose here an other patch
 apparently not tested. With your tests published on forumsig.org, I agree
 with a patch with +wktext alone.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3437#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
