[QGIS-trac] Re: [Quantum GIS] #3468: Missing layer in project means I can't load project at all
Quantum GIS qgis at qgis.org
Fri Mar 4 15:50:02 EST 2011
   Reporter:  arencambre                        |              Owner:  timlinux
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Project Loading / Saving          |            Version:  1.6.0
   Keywords:                                    |   Platform_version:  7
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
Changes (by timlinux):
  * owner:  sunilkcube => timlinux
Comment:
 Hi
 I committed the patch supplied by Sunilraj r15332 which partially
 addresses this. Sunil, note that if you choose 'OK' then 'Cancel' on the
 subsequent dialog, the project is returned to blank - I'm not sure if that
 would be expected behavior. I think it would be better to revert to
 'ignore missing' behaviour if cancel is pressed on the file selection
 dialog.
 I also tidied up the dialog wording a little in r15333.
 Regards
 Tim
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3468#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
