[QGIS-trac] Re: [Quantum GIS] #3586: use authid instead of proj.4 strings
Quantum GIS qgis at qgis.org
Thu Mar 10 04:46:08 EST 2011
   Reporter:  jef                               |              Owner:  jef
       Type:  patch                             |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Projection Support                |            Version:
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
Comment(by borysiasty):
 I've slightly modified your patch:
 1. Also save the authid to QSettings, not only read ;-) (qgsoptions.cpp
 642 and 646)
 2. Use ''layerDefaultCrs'' Qsettings key instead of misleading
 ''defaultCrs''. As the patch breaks this setting anyway, I take a
 opportunity to clean up a bit. (qgsoptions.cpp 191 and 642; qgisapp.cpp
 361)
 By the way. Seems it works not only with epsg ids. Is the note in api doc
 out of date?
 http://doc.qgis.org/head/classQgsCoordinateReferenceSystem.html#5789a11684af1415ffc74d7ce9ab91f0
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3586#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
