[QGIS-trac] Re: [Quantum GIS] #3099: Projection Failure
Quantum GIS qgis at qgis.org
Thu Mar 17 23:25:06 EDT 2011
   Reporter:  badams                            |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Projection Support                |            Version:
   Keywords:  Projection Failure                |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
Changes (by custard):
  * platform:  Windows => All
Comment:
 as at 1.7 r15530
 From a quick test with the dev version isn't (r15530) and a set of single
 point shape files in AMGz51, MGAz51 and WGSz51s.
 - the AMGz51 point won't display in MGAz51 or WGSz51s.
     QGIS puts up a window saying "Could not draw ShapeFile because:" and
 not giving a reason.
     The debug information says: "failed with error: failed to load datum
 shift file"
 - the MGAz51 and WGSz51s points won't display in AMGz51 and fail with the
 same set of errors.
 More debug available if anyone wants it.
 (and this bug exists in my unbuntu install too).
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3099#comment:21>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
