[QGIS-trac] [Quantum GIS] #3646: GRASS toolbox: error removing vectors from a mapset under Windows
Quantum GIS qgis at qgis.org
Sun Mar 20 08:34:47 EDT 2011
   Reporter:  lutra                             |              Owner:  rblazek
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  GRASS                             |            Version:  1.6.0
   Keywords:                                    |   Platform_version:
   Platform:  Windows                           |           Must_fix:  Yes
Status_info:  0                                 |
 Since 1.6 (so it works fine under 1.5) every time a user tries to remove a
 vector map in GRASS toolbox browser using the proper toolbar button
 results in the following error message
 Cannot delete map XXX
 command: regio g.remove.exe
 vect=XXX
 the vector is then not completely removed from the mapset.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3646>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
