[QGIS-trac] [Quantum GIS] #3651: label rotation not working as expected
Quantum GIS qgis at qgis.org
Sun Mar 20 17:54:11 EDT 2011
   Reporter:  jctull                            |              Owner:  mhugent
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Vectors                           |            Version:  Trunk
   Keywords:  label rotation                    |   Platform_version:
   Platform:  OS X                              |           Must_fix:  No
Status_info:  0                                 |
 For new generation labeling, in order to get field-based rotation to work
 (or even show fields as available), you must also set x and y fields.
 Additionally, the rotations are not applied unless you edit the layer and
 move a label.
 The expectation is that you can set a field for rotation whether or not
 you have x and y position fields for a given layer. Additionally, the
 rotation should be applied without having to first edit the individual
 labels.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3651>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
