[Qgis-us-user] Vote on GitHub vs Redmine and a Question
Randal Hale rjhale at northrivergeographic.com
Mon Feb 5 05:42:48 PST 2018
Sorry for the late reply back - I don't think there is a way to see the
code running. I'm somewhat hitting the same problem since I'm writing
some python that might morph into a plugin...maybe - if I do this right.
So I'm sorta picking at this to see what I can/can't do.
In 2.18 you can go to processing -> history you can see some of the
syntax and you should be able to look at the log tab in processing (make
sure to not close the dialog when finished running) to see how the code
is running which might give you some clues on python but probably not
enough.
On 02/01/2018 05:56 PM, Craig Campbell wrote:
> Kurt - As a very new QGIS user I will be happy to go with the majority
> on the GitHub vs Redmine vote
> To All - Originally an ArcGIS guy for 30 years I did a lot of VBA in
> ArcMap (until they killed it) and I transitioned to Model Builder &
> Python.  For the last three years, I have been working in a MapInfo
> environment at my job. MapInfo uses MapBasic and when you run most
> menus and have the MapBasic Console Window open you see the actual
> code that has just run.  In QGIS, I have opened the Python window and
> in my work so far I don’t see and Python script showing.  Is there a
> way to make QGIS display the Python it is running as you make menu
> choices?
> Thanks to all,
> Craig Campbell, Database Coordinator
> */New Picture/*
> 50 S. Cole Rd.• Boise, ID 83709
> Office: (208) 287-0062• Fax: (208) 377-3742
> Mobile: (208) 871-2636• Website: /www.Digline.com
> <http://www.digline.com/>/__
> Qgis-us-user mailing list
> Qgis-us-user at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-us-user
Randal Hale
https://www.northrivergeographic.com
(423)653-3611
URL: <http://lists.osgeo.org/pipermail/qgis-us-user/attachments/20180205/2146fbc1/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-us-user/attachments/20180205/2146fbc1/attachment-0001.png>
More information about the Qgis-us-user mailing list
