[Qgis-us-user] I am a beginner GIS person....HELP
etvander65 at gmail.com etvander65 at gmail.com
Wed Jun 6 15:52:02 PDT 2018
Randy – I think I understand where you are going with this. Let me see if I can share a little more information on what I have and what I ultimately want to do.  I have a street map of the entire Los Angeles County that I downloaded from the LA County Dept. Public Works website.  The map includes data on all of the houses within the county. My community, Altadena is in Unincorporated LA County.  Altadena has a little over 15,000 homes.  Our program, Map Your Neighborhood reaches out to folks that are interested in bringing their neighborhood (10 to 30 homes) together to organize as a group to help each other out in the event of a disaster (911 emergency services will not be available).  We have trained over 50 neighborhoods totally over 1200 homes. I would like to be able to present these graphically by either drawing a shape around the neighborhood or highlighting the homes (as you may have been suggesting below).  The attribute table I assume contains all of the data from all of the items from LA County. It would be nice to parse this down to just the area I am working with and go from there.  But I get the feeling I am asking you all too much.  Please tell me if this out of your scope.
Eric T. Vander Velde (KK6YVS)
Geologist
1059 New York Drive
Altadena, CA 91001
Cell: 818-391-4247
 <mailto:etvander65 at gmail.com> etvander65 at gmail.com
From: Randal Hale <rjhale at northrivergeographic.com>
Sent: Tuesday, June 5, 2018 6:42 PM
To: etvander65 at gmail.com; 'Tim Sutton' <tim at kartoza.com>
Cc: qgis-us-user at lists.osgeo.org
Subject: Re: [Qgis-us-user] I am a beginner GIS person....HELP
So there's one other way to tackle this - and I guess that depends on your data.
**IF** the areas have a field for Disaster Preparedness training - as in you open the attribute table for your data and you have a "training" column and in that column there is a "yes" or "true" er- you can symbolize the data on that field. Which would sorta make your "selection" somewhat permanent.
Which may not make sense....Could you share a copy of your data? That might help. You're almost there it sounds like. You could send it over email just to me and tim or share it through dropbox. We'll delete it when done!
Randy
On 06/05/2018 07:21 PM, etvander65 at gmail.com <mailto:etvander65 at gmail.com>  wrote:
So, back kind of where I was before.  No I am able to select and both drag the area and draw a polygon around the area.  When I use the default drag the area after dragging the area and when I let go of the cursor the area disappears. In addition, when I drag and highlight the area I do not know how to make it stick.  When I finish the polygon it wants to keep drawing the highlighted area wherever I drag the cursor.  I am missing something here.
From: Tim Sutton  <mailto:tim at kartoza.com> <tim at kartoza.com>
Sent: Monday, June 4, 2018 11:45 PM
To: Randal Hale  <mailto:rjhale at northrivergeographic.com> <rjhale at northrivergeographic.com>
Cc: etvander65 at gmail.com <mailto:etvander65 at gmail.com> ; qgis-us-user at lists.osgeo.org <mailto:qgis-us-user at lists.osgeo.org>
Hi Eric
As an alternative to Randal’s good advice, if you simply want to highlight existing features in your houses layer do this:
* select the houses layer in the layers list
* use the selection tools icons (as shown below) to select the selection mode you want to use. The default select feature(s) option will let you simply drag a box around your houses. Other options will let you draw a free-hand region around them etc.
*now drag a region on the map that encloses the houses
* the houses will be highlighted in yellow
* your selection will also be made in the attribute table of that layer
* you can also save out those selected features to make a new layer using Layer -> Save as …. From the menu and checking the ‘save selected features only’ box.
Hope that helps!
Regards
Tim
On 05 Jun 2018, at 02:16, Randal Hale <rjhale at northrivergeographic.com <mailto:rjhale at northrivergeographic.com> > wrote:
Hey - welcome to the group!
So I'm going to assume you're working in shapefiles - do this.
1. Click on Layer at the top of QGIS
2. Click on Create Layer -> New Shapefile
3. You will need to supply a projection and pick if you want points, lines, or polygon (hint polygon). From there you just need to edit your new layer. Click the Pencil (toggle editing) and use the add feature tool to draw it. Don't forget to save.
Randy
On 06/04/2018 05:55 PM,  <mailto:etvander65 at gmail.com> etvander65 at gmail.com wrote:
Hello – I have only taken one class on GIS and then downloaded QGIS.  I was able to download files to create a base map (which includes houses).  What I am trying to do is draw a polygon around certain groups of houses to highlight them. I know I need more instruction. I am lost.  Help if you can.  Thank you.
Geologist
1059 New York Drive
Altadena, CA 91001
Cell: 818-391-4247
Qgis-us-user mailing list
 <mailto:Qgis-us-user at lists.osgeo.org> Qgis-us-user at lists.osgeo.org
 <https://lists.osgeo.org/mailman/listinfo/qgis-us-user> https://lists.osgeo.org/mailman/listinfo/qgis-us-user
Randal Hale
North River Geographic Systems, Inc
 <mailto:rjhale at northrivergeographic.com> rjhale at northrivergeographic.com
(423) 653-3611
 <https://www.northrivergeographic.com/> https://www.northrivergeographic.com
Tim Sutton
Co-founder: Kartoza
Ex Project chair: QGIS.org <http://QGIS.org>
Visit http://kartoza.com <http://kartoza.com/>  to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net <http://freenode.net>
Randal Hale
(423)653-3611
URL: <http://lists.osgeo.org/pipermail/qgis-us-user/attachments/20180606/7169dc81/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-us-user/attachments/20180606/7169dc81/attachment-0001.jpg>
More information about the Qgis-us-user mailing list
