[Qgis-user] Problem compiling...
Stefano Rossi stefano_rossi77 at infinito.it
Sat Apr 22 13:25:44 EDT 2006
I'm trying to compiling Qgis-0.7.3 using a PC with Suse 10.0.
When I run 'make', my system start compiling then stop with this exit
status:
-qgsrunprocess.moc.o .libs/libqgis_la-qgsscalecalculator.o
.libs/libqgis_la-qgssimarenderer.o
.libs/libqgis_la-qgssinglesymrenderer.o
.libs/libqgis_la-qgsspatialrefsys.o .libs/libqgis_la-qgssymbol.o
.libs/libqgis_la-qgsuniquevalrenderer.o
.libs/libqgis_la-qgsuvalmarenderer.o
.libs/libqgis_la-qgsvectordataprovider.o
.libs/libqgis_la-qgsvectordataprovider.moc.o
.libs/libqgis_la-qgsvectorfilewriter.o .libs/libqgis_la-qgsvectorlayer.o
.libs/libqgis_la-qgsvectorlayer.moc.o .libs/libqgis_la-qgspgutil.o
-Wl,--rpath -Wl,/usr/lib/qt3/lib -Wl,--rpath -Wl,/usr/lib/qt3/lib
-L/usr/lib/qt3//lib /usr/lib/qt3/lib/libqt-mt.so -L/usr/local/lib
/usr/local/lib/libgdal.so /usr/lib64/libsqlite3.so
-L/usr/lib64/gcc/x86_64-suse-linux/4.0.2
-L/usr/lib64/gcc/x86_64-suse-linux/4.0.2/../../../../x86_64-suse-linux/lib -L/usr/lib64/gcc/x86_64-suse-linux/4.0.2/../../../../lib64 -L/usr/lib64/gcc/x86_64-suse-linux/4.0.2/../../.. -L/lib/../lib64 -L/usr/lib/../lib64 /usr/lib64/libstdc++.so -lm -lc -lgcc_s /usr/lib64/gcc/x86_64-suse-linux/4.0.2/crtendS.o /usr/lib64/gcc/x86_64-suse-linux/4.0.2/../../../../lib64/crtn.o  -Wl,-soname -Wl,libqgis.so.0 -o .libs/libqgis.so.0.0.1
/usr/lib/qt3/lib/libqt-mt.so: could not read symbols: File in wrong
format
collect2: ld returned 1 exit status
make[4]: *** [libqgis.la] Error 1
make[4]: Leaving directory `/home/ste/qgis-0.7.3/src'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/ste/qgis-0.7.3/src'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/home/ste/qgis-0.7.3/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/ste/qgis-0.7.3'
make: *** [all] Error 2
ste at linux:~/qgis-0.7.3>
My Qt version is 3.3.4 (installed from RPM's )
Can anyone solve my problem ?
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20060422/98918a9a/attachment.html
