[Qgis-user] Configure issues
Radim Blazek radim.blazek at gmail.com
Fri Aug 11 11:26:50 EDT 2006
GRASS header files very moved from grass/include/
to grass/include/grass/ this spring. Consequently
QGIS 0.7 HEAD does not compile with GRASS HEAD.
You are probably compiling QGIS 0.7? I would recommend
to use QGIS 0.8 preview or HEAD. Other possibility is
to make symlinks or copy headers from grass/include/grass/
to grass/include/
Sorry for inconvenience, I tried to convince GRASS developers
to keep headers in both dirs for a while but that would be probably
too simple ...
Radim
On 8/11/06, Sampson, David <dsampson at nrcan.gc.ca> wrote:
> Hey Yall
> Gentoo LINUX box
> GRASS runs fine
> QGIS is a fun issue to install… beeen working on it for a while.
> Here is my config script so far:
> ./configure
> --prefix=/usr/local/qgis
> --with-x
> --with-gdal=/usr/bin/gdal-config
> --with-geos=/usr/bin/geos-config
> --with-postgresql=/usr/bin/pg_config
> --with-grass=/usr/local/grass-6.1.cvs
> --with-qtdir=/usr/qt/3
> Here is my next error:
> checking for GRASS... ls: /usr/local/grass-6.1.cvs/include/gis.h: No such
> file or directory
> configure: error: GRASS headers not found
> The config script works for the libraries but I have one more diretcory tree
> to drive down into for the include files (headers?)
> ls /usr/local/grass-6.1.cvs/include/grass/
> CC.h          config.h    gis.h        interpf.h     portable.h    spawn.h
> D.h           dataquad.h  gisdefs.h    keyframe.h    proto_dbmi.h  sqlp.h
> G3d.h         datetime.h  glocale.h    kftypes.h     qtree.h
> std_incs.h
> P_datetime.h  dbmi.h      gmath.h      la.h          raster.h      symbol.h
> P_site.h      devlib.h    gproj_api.h  label_bm.h    readsites.h
> transform.h
> Paintlib.h    dgl         gprojects.h  lapack.h      region_bm.h   vask.h
> V_.h          dgl.h       graphics.h   libtrans.h    rowio.h
> vbuildlib.h
> Vect.h        dig_atts.h  gstypes.h    linkm.h       rtree         vect
> bdlg_bm.h     display.h   gsurf.h      lock.h        rtree.h       version.h
> bitmap.h      dlg.h       help.h       lrs.h         search.h
> waterglobs.h
> blas.h        dlg_bm.h    ibtree.h     monitors.h    segment.h     winname.h
> btree.h       edit.h      icon.h       ogsf_proto.h  shapefil.h
> cdhc.h        form.h      icon_bm.h    ortholib.h    shhopt.h
> codes.h       geo.h       imagedefs.h  patterns.h    site.h
> colors.h      geom.h      imagery.h    pbmplus.h     sitelib.h
> Any ideas?
> Cheers
> Qgis-user mailing list
> Qgis-user at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-user
