[Qgis-user] Re: Re: Re: Re: Error in print: Cannot find BoundingBox
Radim Blazek radim.blazek at gmail.com
Sun Dec 3 11:20:17 EST 2006
http://www.trolltech.com/developer/notes/changes/changes-4.2.2/ :
"Ensured that QPrinter doesn't generate PDF when printing to raw CUPS printers."
Radim
On 12/1/06, Henning Lorenz <henning.lorenz at geo.uu.se> wrote:
> The document format is PDF1.4, not EPS as it should be. Sometimes the
> "Cannot find translate error", which Maciej mentioned, pops up - but not
> regularly and reproduceable - and I can't figure out what triggers it. If
> this happens the PDF.eps file is corrupted, if not the file seems to be
> fine.
> Henning
> On Thu, 30 Nov 2006 16:34:44 +0100, Radim Blazek wrote:
> > On 11/30/06, Henning Lorenz <henning.lorenz at geo.uu.se> wrote:
> >> Yes, its ".eps". It's possible to display the eps-file in DocumentViewer
> >> and it looks allright. So the error is just irritating. However it might
> >> be difficult to print an eps-file without BoundingBox.
> > Vice versa, you need the BoundingBox for EPS, not for PS.
> > And what is the document format, the first line in the file?
> > Radim
> >> Henning
> Qgis-user mailing list
> Qgis-user at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-user
