[Qgis-user] problems with GUI text
G. Allegri
giohappy at gmail.com
Wed Dec 13 09:04:30 EST 2006
I solved the problem (hoping it's a stable solution!) compiling Qt 4.2.2 qnd
QGi 0.8.0 Preview2 by myself.
Therefore it was a problem related to my Qt 4 packages.
Thanks everyone for the support.
Giovanni
2006/12/13, Akio Takubo <takubo at saruga-tondara.net>:
> Hello Giovanni,
> I have a same problem with my Debian PC. I'm not sure of its details, but
> it seems to be related a problem between Qt4 package and X drivers.
> It works fine with VESA driver or other PC (with radeon driver),
> but can't work with NVIDIA or NV driver.
> One idea is trying other Qt4 applications (Debian has some Qt4 app).
> If other app have same problem, it is a Qt4 or its packageing problem,
> but other app works fine with same driver, there is something wrong
> with QGIS code.
> Regards,
> Akio Takubo
> On Tue, 12 Dec 2006 13:37:58 +0100
> "G. Allegri" <giohappy at gmail.com> wrote:
> > Yes I did. It worked fine. Everything looked visually smart inside the
> > config tool. I tried changing some parameters but nothing seems to
> solve. In
> > particular, when I open the QGis Plugin Menu, it's unreadable (or
> better, it
> > seems to shrink and overlap the letters...), while sometimes it renders
> good
> > if I resize the menu window. That doesn't happen on the other texts of
> the
> > main window... I never had this kind of problem on any other software,
> but I
> > think Qgis is the only one using Qt. Maybe I should try to uninstall the
> > fedault qt4 package and compile it form source. Could it be a good idea?
> > 2006/12/12, Gary Sherman <sherman at mrcc.com>:
> > > Did you run qtconfig?
> > > On Dec 11, 2006, at 4:26 PM, G. Allegri wrote:
> > > nothing happened. I didn't have qtfontig installed, but installing it
> > > did'nt seem to solve my problem. Using QGis during the day I've seen
> that
> > > sometimes characters are correctly displayed, but just for a while...
> Then
> > > they become unreadable again. I'm going crazy!
> > > Giovanni
> > > > On Dec 11, 2006, at 3:12 PM, G. Allegri wrote:
> > > > Hello.
> > > > I'm a new QGis user. I've installed QGis 0.8 preview 2 (
> debian.gfossrepository) on my laptop and I'm facing a problem with the
> texts in the UI,
> > > > as you can see in this screenshot<
> http://www.box.net/index.php?rm=box_v2_download_shared_file&file_id=f_31418148
> > > > I installed it, the same way, on a desktop PC and it works fine.
> I've tried
> > > > to compile it, but the same problem remains. Could it be a problem
> related
> > > > to my video card? It's an Ati Radeon IGP 320 (U1 driver,
> automatically
> > > > installed by my Debian).
> > > > Any suggestion?
> > > > Try running the qtconfig program (comes with Qt) and checking or
> > > > adjusting the fonts used by Qt. It is possible that Qt is having
> trouble
> > > > mapping default fonts to those available on your system.
> > > > -gary
> > > > -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
> > > > Gary Sherman
> > > > Micro Resources: http://mrcc.com
> > > > *Geospatial Hosting
> > > > *Web Site Hosting
> > > > "We work virtually everywhere"
> > > Gary Sherman
> > > *Geospatial Hosting
> > > *Web Site Hosting
> Qgis-user mailing list
> Qgis-user at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-user
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20061213/e676e93d/attachment.html
