[Qgis-user] GPS plug in
Tim Sutton tim at linfiniti.com
Tue Jun 20 10:05:51 EDT 2006
Hi
As far as I know it will look in the normal PATH. Just make sure your
PATH includes the dir where gpsbabel lives. If you are running Linux
and you installed gpsbabel from package, this should be automatically
available.
There is an option to set this in the user level settings file, but I
dont see anywhere in the gui that lets you configure that. However
generally you shouldnt need to do that anyway.
Regards
Tim
On 20/06/2006, at 10:37, Jonathan Boyd Thayn wrote:
> Another simple question:
> These are the instructions on the GPS plugin:
> This tool uses the program GPSBabel (http://gpsbabel.sf.net) to
> transfer the data. If you don't have GPSBabel installed where QGIS
> can find it, this tool will not work.
> Where do I install GPSBabel?  Where does QGIS look?
> Jonathan B. Thayn
> Kansas Applied Remote Sensing (KARS) Program
> University of Kansas
> Higuchi Hall
> 2101 Constant Avenue
> Lawrence, Kansas 66047-3759
> jonthayn at ku.edu
> www.kars.ku.edu/about/people/thayn/JonSite/Welcome.html
> Qgis-user mailing list
> Qgis-user at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-user
Tim Sutton
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20060620/cbda2fc1/attachment.html
