[Qgis-user] Re:
Tim Sutton
tim at linfiniti.com
Tue Mar 28 09:02:21 EST 2006
Hi
This sounds like its squarely in the Radim department. I would suggest
upgrading to the lastest stable verion (0.7.4) as the issue encounter
may have been addressed in one of the bug fix releases.
Regards
Tim
On 3/28/06, Dave Kindem <dkindem at structureinteractive.com> wrote:
> Hi Tim,
> I'm using version 0.7.0.
> I launch the program from inside GRASS, and use the Add GRASS Vector layer
> function. As long as i was displaying vectors that had been created in
> GRASS using v.in.ascii, things seemed to work fine. Now I'm trying to
> display layers that were brought into GRASS from Postgres using v.in.db,
> reprojected from ll to UTM in GRASS, and displayed in QGIS. The table
> behind the layer has 4 columns, OID, Latitude, Longitude and Name.
> Thanks in advance.
> Dave
> On Mar 28, 2006, at 4:43 AM, Tim Sutton wrote:
> Hi
> Which version of QGIS are you using?
> Are you trying to display the imported grass layers or the layer
> straight out of postgresql?
> Regards
> Tim
> On 3/26/06, David Kindem <dkindem at chartermi.net> wrote:
> Hello,
> I'm a little confused about error messages I am receiving in QGIS.
> I've launched QGIS from GRASS, and am attempting to display GRASS
> vector layers imported into GRASS from PostSQL using v.in.db. The
> vector layers display properly in GRASS.
> However, when I attempt to add them to the display in QGIS, I receive
> a message the the Key Column 'OID' is not found in the table for the
> vectors. I've looked at the table columns in both GRASS and PostSQL,
> and see and OID column in the table. Does anyone know what I need to
> do to make QGIS see the column?
> Thanks for any help,
> Dave
> Qgis-user mailing list
> Qgis-user at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-user
> Tim Sutton
> Visit http://qgis.org for a great Open Source GIS
> Skype: timlinux
> MSN: tim_bdworld at msn.com
> Yahoo: tim_bdworld at yahoo.com
> Jabber: timlinux
> Irc: timlinux on #qgis at freenode.net
Tim Sutton
Skype: timlinux
Jabber: timlinux
