[Qgis-user] Re:
Radim Blazek radim.blazek at gmail.com
Tue Mar 28 09:59:31 EST 2006
I don't know. It could be that mapset is not reset correctly in 0.7.0.
Try to start QGIS from GRASS shell and open only the single vector.
Radim
On 3/28/06, Tim Sutton <tim at linfiniti.com> wrote:
> Hi
> This sounds like its squarely in the Radim department. I would suggest
> upgrading to the lastest stable verion (0.7.4) as the issue encounter
> may have been addressed in one of the bug fix releases.
> Regards
> Tim
> On 3/28/06, Dave Kindem <dkindem at structureinteractive.com> wrote:
> > Hi Tim,
> > I'm using version 0.7.0.
> > I launch the program from inside GRASS, and use the Add GRASS Vector layer
> > function.  As long as i was displaying vectors that had been created in
> > GRASS using v.in.ascii, things seemed to work fine.  Now I'm trying to
> > display layers that were brought into GRASS from Postgres using v.in.db,
> > reprojected from ll to UTM in GRASS, and displayed in QGIS.  The table
> > behind the layer has 4 columns, OID, Latitude, Longitude and Name.
> > Thanks in advance.
> > Dave
> > On Mar 28, 2006, at 4:43 AM, Tim Sutton wrote:
> > Hi
> > Which version of QGIS are you using?
> > Are you trying to display the imported grass layers or the layer
> > straight out of postgresql?
> > Regards
> > Tim
> > On 3/26/06, David Kindem <dkindem at chartermi.net> wrote:
> > Hello,
> > I'm a little confused about error messages I am receiving in QGIS.
> > I've launched QGIS from GRASS, and am attempting to display GRASS
> > vector layers imported into GRASS from PostSQL using v.in.db.  The
> > vector layers display properly in GRASS.
> > However, when I attempt to add them to the display in QGIS, I receive
> > a message the the Key Column 'OID' is not found in the table for the
> > vectors.  I've looked at the table columns in both GRASS and PostSQL,
> > and see and OID column in the table.  Does anyone know what I need to
> > do to make QGIS see the column?
> > Thanks for any help,
> > Dave
> > Qgis-user mailing list
> > Qgis-user at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-user
> > Tim Sutton
> > Visit http://qgis.org for a great Open Source GIS
> > Skype: timlinux
> > MSN: tim_bdworld at msn.com
> > Yahoo: tim_bdworld at yahoo.com
> > Jabber: timlinux
> > Irc: timlinux on #qgis at freenode.net
> Tim Sutton
> Skype: timlinux
> Jabber: timlinux
