[Qgis-user] qgis - grass integration ; new modules
Radim Blazek radim.blazek at gmail.com
Mon Sep 18 04:48:43 EDT 2006
On 9/16/06, massimodisasha <massimodisasha at yahoo.it> wrote:
> hi, i'm tring to add some grass command to qgis-grass plug-in module,
> but i've some problem :
> for a long module such as r.sun >>
> <?xml version="1.0" encoding="UTF-8"?>
> <!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
> <qgisgrassmodule label="display composite map from his image "
> module="r.sun">
>          <flag key="s" />
>         <option key="elevin" />
>          <option key="aspin" />
>          <option key="slopein" />
>          <option key="linkein" />
>          <option key="lin" />
>          <option key="albedo" />
>          <option key="alb" />
>          <option key="latin" />
>          <option key="lat" />
>          <option key="coefdh" />
>          <option key="incidout" />
>          <option key="beam_rad" />
>          <option key="insol_time" />
>          <option key="diff_rad" />
>          <option key="day" />
>          <option key="step" />
>          <option key="declin" />
>          <option key="time" />
> </qgisgrassmodule>
> i've problem to visualiz the module window, beacouse it is more large
> than the monitor :-( how can i add a crollbar in a module???
> i'm looking for a xml tutorial, can any help me?
This must be changed in C++, you can fill a new ticket(bug) for 0.9.
> the original nviz module not work, i rewrited it, identically the
> original nviz.qgim and rename it nvis.qgm
> then i add it in defoul.qgc  now it works,
>   but only if i load a ( elevation + color + vector ) file
> if i want load nviz with only elevation data, it do not work...(how
> can i set the "option" and "required" option ?)
This is not supported, you can add a new wish/improvement ticket
for 0.9.
Radim
> this is the r.sun modules screenshots:
> this is what i have on my screen when i launch the module
> http://img205.imageshack.us/img205/3241/immagine1iv5.png
> and this is the same module when i check on my OS whats windows are
> open... you can si how it is long
> http://img176.imageshack.us/img176/29/immagine2jl5.png
> i use qgis0.8 preview2 on mac osx on a laptop 12"
> thanks for any suggestion.
> Massimo.
> Qgis-user mailing list
> Qgis-user at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-user
