[Qgis-user] Populating area in the attribute table
James Sewell
jcsewell at shaw.ca
Mon Apr 9 17:10:42 EDT 2007
Gary Sherman wrote:
> Probably the easiest way to do this is to load your data into PostGIS.
> You can create an area column for the layer, then use the area
> function to calculate areas for each geometry and populate the area
> column.
Hi Gary, thanks for the response.
I think I can handle getting the data into PostGIS (never done it but
I've seen it in the docs).
My question is about the "area function". Is this a PostGIS function or
QGIS? Is the function documented somewhere?
-James
