[Qgis-user] Helmert transform in Georeferencer plugin is broken
Tim Sutton tim at linfiniti.com
Wed Dec 5 19:16:21 EST 2007
Hi
I suggest asking Marco Hugentobler about this. Filing a bug would
probably be a good idea too - it would be helpful if you can include
some test data with any bug report you file. Contact me if you need an
account on https://svn.qgis.org/trac to file your report.
Regards
Tim
2007/12/5, peter <webtmc at telusplanet.net>:
> I did some more testing with the Georeferencer plugin...
> If I do a linear transform, my georeferenced aerial photo loads fine, the UTM
> coordinates are correct, and the vector shape file loads over top of the
> photo. Both layers are in the same extent. Everything works as it should,
> although the roads of the vector layer do not quite line up with the roads on
> the raster photo. The photo needs to be rotated slightly, which is why I need
> to do a Helmert transform...
> However, if I try to do a Helmert transform, the resultant raster and vector
> files are not in the same extent. The vector layer appears as a little dot to
> the left and off of the raster layer, even though the raster is actually a
> small portion of the vector layer area. The coordinates on the raster layer
> look more like the x,y coordinates of the raster pixels, rather than the UTM
> coordinates.
> In discussing this on the #qgis chatroom, it appears as though the world file
> is incorrect after the transform.
> The linear world file is:
> 1.258047197754220
> 0
> 0
> -1.152181167169244
> 363616.681031816115137
> 5513234.182411503046751
> However the Helmert modified world file is:
> 1.000000000000000
> 0
> 0
> -1.000000000000000
> 363627.532545701600611
> 5513436.412385137751698
> Does this sound like it could be a bug in the plugin? Any other ideas? Thanks.
> Peter Pankonin, digitalcrucible
> There are 10 kinds of people in the world,
> those who understand binary, and those who don't.
> Qgis-user mailing list
> Qgis-user at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-user
Tim Sutton
QGIS Project Steering Committee Member - Release  Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
